How do I turn on Color Night Vision?
Turn off Night Vision (no, really).
By default, Wyze Cam Floodlight will automatically turn on when motion is detected. While viewing the live stream, turn off night vision. The camera will switch to color night vision.
Only a little light is needed for a clear image and a street light or night light outside works. If you need more light, you can manually turn on the floodlight in the Wyze app for better illumination.
