How do I factory reset my Wyze Indoor Cam Pan?
To factory reset Wyze Indoor Cam Pan:
  1. Remove any microSD card that is inserted into the camera.
  2. With the camera powered on, manually adjust the camera lens so that it is pointing up.
  3. Below the camera lens, press and hold the setup button for 10 seconds until the status light on the front of the camera turns solid red.
  4. Once the status light starts flashing red, set up the camera as new.
When your camera is factory reset:
  • The device settings and previous Wi-Fi/setup state are cleared.
  • The current firmware version remains intact.
  • The camera must be set up as a new device before it can be used again.
