Problem
My Wyze Indoor Cam Pan’s status light is solid red and won’t change.
Note: A solid red light on Wyze Indoor Cam Pan means that the camera is powered on and initializing, recording an event, or live streaming.
Troubleshooting
- Make sure that the camera is being powered using the power cable and adapter that came with the camera.
- If using the original power cable and adapter, try another power cable and adapter if possible.
- Wyze Indoor Cam Pan requires a 5V 1.5A power adapter.
- Power cycle Wyze Indoor Cam Pan.
- Unplug the camera from its power source for 5-10 seconds, then plug it back in.
- Try plugging the camera into a different power outlet.
- Factory reset the camera and then set it up as new.
- Remove any microSD card that is inserted into the camera.
- With the camera powered on, manually adjust the camera lens so that it is pointing up.
- Below the camera lens, press and hold the setup button for 10 seconds until the status light on the front of the camera turns solid red.
- Once the status light starts flashing red, set up the camera as new.
