To factory reset Wyze Lock Bolt:
- Get within Bluetooth range of the lock (16 feet or less).
- In the Wyze app, tap on your Wyze Lock Bolt.
- Tap Settings > Delete Device.
- You will hear a short series of beeps that will confirm a successful factory reset.
- Set up the lock as a new device.
Warning: If you press the pairing button and take out the battery during the pairing period, the Wyze Lock Bolt will delete everything stored in the device (all users and settings). Don't try pairing and power cycling at the same time. Wait for re-pairing to finish first.
