How do I get Cloud 60?
To add Cloud 60 to a camera in the Wyze app:
Make sure the camera already has an active Cam Plus or Cam Unlimited plan. Cloud 60 can't be purchased on its own — it requires an eligible base plan.
  1. Open the Wyze app.
  2. Go to Account > Services.
  3. Select Cloud 60.
  4. Select the eligible camera(s).
  5. Complete your purchase.
Once purchased, 60-day storage turns on automatically for that camera. You don't need to change any other settings.
Additional Notes:
  • Cloud 60 can't be applied retroactively — it won't restore events older than 14 days that have already expired.
  • If your account has mixed or multiple plans, the app may direct you to my.wyze.com for easier management.
