My Wyze Room Sensor is not updating its status.
Problem
There's a change in humidity or temperature, but Wyze Room Sensor is not displaying the change. The temperature/humidity remains the same.
Troubleshooting
  1. Check that your Wyze app is up to date.
    1. Go to the Account tab > tap About.
    2. The app version will be listed beneath the Wyze logo.
    3. You can compare your app version to the most up-to-date version listed on our Release Notes & Firmware page.
  2. Confirm the firmware for both your Wyze Thermostat and Wyze Room Sensor are up to date.
    2. If there is an update available for your thermostat, please move forward with the update.
  3. Refresh the status of your sensors by swiping down on the page with the list of Wyze Room Sensors in the Wyze app.
  4. Verify if the temperature and humidity level on the sensor changes when it is placed close to cold/hot or humid objects.
  5. Power cycle your Wyze Room Sensor by removing and reinserting the sensor’s batteries.
  6. Try refreshing the sensor list again in the app.
  7. Factory reset your Wyze Room Sensor.
    1. Press and hold the button on the top of the sensor for about 5 seconds until the sensor’s display shows [188] and then release the button to return to the room temperature and humidity display.
    2. Set up your Wyze Room Sensor as new.
