Problem
Your Wyze Battery Cam is unable to be set up.
Troubleshooting
- Confirm that the Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- Check that the camera’s status light is flashing red and that there is a “ready to connect” voice prompt after pressing the setup button.
- The status light for Wyze Battery Cam is on the front of the camera, to the right of the lens.
- If the camera does not show a status light or there is no voice prompt, refer to My Wyze Battery Cam won’t turn on.
- Ensure that Bluetooth® is enabled for the Wyze app in the phone/tablet settings.
- Toggle Bluetooth® off/on.
- Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
- Make sure that it is set to Always or While Using the App.
- For iOS users, make sure that Precise Location is turned on.
- If possible, temporarily disable any VPNs on the mobile device or Wi-Fi router.
- Ensure that the phone/tablet is connected to the same Wi-Fi network that is being entered at the Select your network step, that the SSID (Wi-Fi name) is being entered correctly, and that the network is functioning normally.
- Wyze Battery Cam is only compatible with 2.4 GHz Wi-Fi networks.
- The SSID is case-sensitive, and there should be no space before or after the SSID.
- The SSID should automatically populate if the phone/tablet is connected to Wi-Fi. If it does not auto-populate, it can indicate that the phone/tablet that is being used for setup is not connected to Wi-Fi.
- Check that the Wi-Fi password is entered correctly.
- Tap on the eye icon to view the password entered.
- Make sure the camera and phone/tablet are close to the router (within 6-10 feet) during the setup process.
- Forget the Wi-Fi network and rejoin the network on the phone/tablet, then try setting up the camera again.
- Reboot the Wi-Fi router.
- Factory reset Wyze Battery Cam.
- Remove any microSD card that is inserted into the camera.
- Press and hold the setup button for 10 seconds.
- Once the status light starts flashing red, set up the camera as new.
