My Wyze Battery Cam has poor audio quality.
Problem
You hear poor audio quality when speaking through Wyze Battery Cam or in recorded events; Wyze Battery Cam has low/distorted audio.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Battery Cam’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure there is nothing impairing the camera’s microphone or speaker.
    1. Remove any plastic film/cover from the microphone or speaker.
    2. Gently blow on or wipe the microphone or speaker with a soft cloth to remove any dust or debris.
  4. Verify that audio is enabled in the camera’s live stream.
    1. Navigate to the camera’s live stream.
    2. Tap the live stream, then tap the speaker icon to enable sound.
  5. Ensure Record Sound is enabled.
    1. In the Wyze app, go to the camera’s settings > Advanced Settings.
    2. Toggle on Record Sound.
  6. When viewing recordings, ensure the video sound is not muted.
  7. If experiencing poor audio quality while using the 2-way audio feature:
    1. Ensure Wyze Battery Cam has good signal strength.
      1. You can check this in the Wyze app by going to the camera’s settings > Device Info > Signal Strength.
      2. If it has 2 bars or less, try moving the camera closer to the router.
    2. Lower the live stream’s resolution.
  8. Force close and reopen the Wyze app.
  9. Increase the volume on the phone/tablet.
  10. Test the audio on a different phone/tablet, if possible.
  11. If there is a microSD card inserted into the camera, check the recordings on a computer, if possible, to verify if the audio in the microSD card recordings has the same issue.
  12. Restart the camera.
    1. Navigate to the camera’s settings > Restart Camera > Restart.
  13. Factory reset Wyze Battery Cam.
    1. Remove any microSD card that is inserted into the camera.
    2. Press and hold the setup button for 10 seconds.
    3. Once the status light starts flashing red, set up the camera as new.
