My Wyze Battery Cam won’t turn on.
Problem
Your Wyze Battery Cam’s status light is not lighting up, or the device is not powering on / charging when using a power cable.
Troubleshooting
  1. Make sure the battery is fully charged.
    • The charging indicator light will be solid red while charging and solid blue once fully charged.
    • The charging indicator light for Wyze Battery Cam is on the bottom of the camera.
    • If the battery is not charging, follow the steps in My Wyze Battery Cam is not charging.
  2. Plug Wyze Battery Cam into a standard outlet to charge, making sure that the camera is powered using the power cable that came with the camera.
  3. Verify that the power cable is plugged into a 5V2A power adapter (not included).
    • Using lower-rated power adapters will negatively impact the charging performance.
  4. Ensure the power cable is inserted correctly and securely into the camera and adapter.
  5. If the camera was already set up in the Wyze app, go to the camera’s settings > Advanced Settings > Camera Status Light. Then toggle the light off and on.
  6. Press and hold the setup button to see if you hear a “ready to connect” voice prompt.
    1. If so, proceed to set up the camera as new.
  7. Factory reset Wyze Battery Cam.
    1. Remove any microSD card that is inserted into the camera.
    2. Press and hold the setup button for 10 seconds.
    3. Once the status light starts flashing red, set up the camera as new.
