Problem
Your Wyze Battery Cam shows offline in the Wyze app, loads slowly, or disconnects frequently.
Troubleshooting
- Confirm that the Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that Wyze Battery Cam’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the camera, please move forward with updating it.
- Confirm whether the status light is on.
- If not, refer to My Wyze Battery Cam won’t turn on.
- Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
- Make sure that it is set to Always or While Using the App.
- For iOS users, make sure that Precise Location is turned on.
- Confirm that the Wi-Fi network that the camera is connected to is functioning normally.
- Wyze Battery Cam is only compatible with 2.4 GHz Wi-Fi networks.
- Switch between using the Wi-Fi connection and cellular/mobile data to determine if there is an issue with the Wi-Fi.
- Force close and reopen the Wyze app.
- Ensure Wyze Battery Cam has good signal strength.
- You can check this in the Wyze app by going to the camera’s settings > Device Info > Signal Strength.
- If it has 2 bars or less, try moving the camera closer to the router.
- Adjust the live stream resolution to a lower resolution.
- Higher resolution requires more bandwidth and is more likely to cause slower connectivity.
- Reboot the Wi-Fi router.
- Restart the camera.
- Navigate to the camera’s settings > Restart Camera > Restart.
- Factory reset Wyze Battery Cam.
- Remove any microSD card that is inserted into the camera.
- Press and hold the setup button for 10 seconds.
- Once the status light starts flashing red, set up the camera as new.
