My Wyze Lever Lock’s battery is draining quickly.
Problem
The battery level for your Wyze Lever Lock is draining faster than expected.
Troubleshooting
  1. Ensure the correct batteries are being used.
    • Wyze Lever Lock requires 8x 1.5V AA batteries.
    • Note: We recommend using brand-new batteries, all of the same brand.
  2. Check if the batteries are rechargeable.
    • If so, ensure they are 1.5V. Lower voltage will lead to faster battery drain.
  3. Make sure the batteries are inserted correctly, with the plus signs aligning with plus and the negative sides aligning with negative.
  4. Power cycle Wyze Lever Lock.
    1. Remove all 8 batteries completely for 10 seconds, then place them back into the lock, ensuring they are positioned properly and firmly.
  5. Replace the batteries with brand-new batteries.
    • Note: If using a mix of old and new batteries, the app will incorrectly show 100% battery at the start, but it will drain very quickly.
  6. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  7. If possible, check that Wyze Lever Lock’s firmware is up to date.
    2. If there is an update available for the lock, please move forward with updating it.
  8. Ensure Wyze Lever Lock has good signal strength.
    1. You can check this in the Wyze app by going to the lock’s settings > Device Info > Signal Strength.
    2. If it has 2 bars or less, try moving the router closer to the lock.
  9. Factory reset Wyze Lever Lock.
    1. Remove the cover on the interior assembly by pressing in and up on the top portion of the interior assembly.
    2. Press and hold the reset button for 8 seconds until the status light begins pulsing red.
    3. Once the status light starts pulsing white, set up the lock as new.
Note: Wyze Lever Lock should provide up to 10-12 months of battery life with normal use (an average of 10 locks/unlocks per day).
