Wyze Lever Lock Integrations Troubleshooting
Problem
Wyze Lever Lock is not working with the supported integrations.
Troubleshooting
  1. Confirm that the Wyze app is up to date. 
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Lever Lock’s firmware is up to date. 
    2. If there is an update available for the lock, please move forward with updating it.
  3. Ensure the desired third-party app is functioning normally.
  4. Delete any integrations and set them up again.
    • For Google Home:
      1. Navigate to the lock’s settings > Third Party Integration.
      2. Delete the integration and set it up like new.
    • For Amazon Alexa:
      1. From the Home tab of the Wyze app, select Account.
      2. Select Smart Integrations.
      3. Delete the integration and set it up like new.
