Problem
Wyze Lever Lock is not automatically locking at the time you have set in the Wyze app.
Troubleshooting
- Confirm that the Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that Wyze Lever Lock’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the lock, please move forward with updating it.
- Ensure that Bluetooth® is enabled for the Wyze app in the phone/tablet settings.
- Toggle Bluetooth® off/on.
- Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
- Make sure that it is set to Always or While Using the App.
- For iOS users, make sure that Precise Location is turned on.
- Ensure Wyze Lever Lock has good signal strength.
- You can check this in the Wyze app by going to the lock’s settings > Device Info > Signal Strength.
- If it has 2 bars or less, try moving the router closer to the lock.
- Ensure that the Lock After Hours settings are set correctly.
- In the lock’s settings, tap Auto-Lock Schedule.
- Toggle Lock After Hours off/on.
- The toggle will be green when enabled.
- Verify the schedule is set to the preferred timeframe.
- Set a different schedule to clear any stuck settings, then set it back to the preferred timeframe.
- Test the lock during the set timeframe.
- Verify that there are no Automations set up that could be causing interference.
- Navigate to the Home tab of the Wyze app, tap Automations.
- Note: We recommend deleting any Automations and then adding them back one by one while testing.
- Restart Wyze Lever Lock.
- Navigate to the device’s settings > Restart Device > Restart.
- Power cycle Wyze Lever Lock.
- Remove all 8 batteries completely for 10 seconds, then place them back into the lock, ensuring they are positioned properly and firmly.
- Factory reset Wyze Lever Lock.
- Remove the cover on the interior assembly by pressing in and up on the top portion of the interior assembly.
- Press and hold the reset button for 8 seconds until the status light begins pulsing red.
- Once the status light starts pulsing white, set up the lock as new.
Note: Wyze Lever Locks using firmware version 1.0.2 or newer, the Lock After Hours setting is part of the Auto-Lock Schedule settings. For older firmware, Lock After Hours is its own setting. The above steps reflect the settings for firmware version 1.0.2+.
