Wyze Lever Lock Fingerprint Troubleshooting
Problem
Wyze Lever Lock does not unlock using the fingerprint; the fingerprint recognition is unreliable, inaccurate, or unable to be set up.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Lever Lock’s firmware is up to date.
    2. If there is an update available for the lock, please move forward with updating it.
  3. Make sure there is no debris on the finger reader.
    1. Gently wipe it with a soft, dry cloth.
  4. Ensure there is nothing blocking the finger from being scanned, such as:
    • Excess oil, water, or debris on the finger.
    • Gloves, paint, or large jewelry/accessories.
    • Any items being held, such as keys.
    • Any stickers or labels that came on the device.
  5. Verify that the lock is awake before scanning.
    1. Tap the keypad display to ensure it is awake.
  6. Make sure the finger is positioned properly while scanning.
    1. Place the finger at the same angle and position used during enrollment.
    2. Gently press on the reader and hold steady for about 1 second.
  7. Check the number of times the scan was unsuccessful.
    • Failed Entry Lockout is enabled by default, and if the scan fails 5 times in a row, the finger scan functionality will be disabled for 5 minutes.
      • If the lockout period is active, use an alternate access method (key, code, app, etc.) or wait until the lockout period is over.
      • This feature can be disabled by going to the lock’s settings > Failed Entry Lockout.
  8. Remove the fingerprints associated with the user profile and create new ones.
    1. In the lock’s settings, tap Access and Sharing.
    2. Select the correct user profile.
    3. Tap the trash icon next to existing fingerprints, then follow the in-app instructions to create new ones.
  9. For shared users, reach out to the account/device owner to verify your permission level.
    • Shared user access can be set to Always, Recurring, or Custom.
  10. Restart Wyze Lever Lock.
    1. Navigate to the device’s settings > Restart Device > Restart.
  11. Power cycle Wyze Lever Lock.
    1. Remove all 8 batteries completely for 10 seconds, then place them back into the lock, ensuring they are positioned properly and firmly.
  12. Factory reset Wyze Lever Lock.
    1. Remove the cover on the interior assembly by pressing in and up on the top portion of the interior assembly.
    2. Press and hold the reset button for 8 seconds until the status light begins pulsing red.
    3. Once the status light starts pulsing white, set up the lock as new.
Note: When enrolling the fingerprint, make sure the whole fingerprint is covering the reader with no gaps, but do not press too hard, as that will negatively impact performance. Children under 10 years old and seniors over 60 years old may have a lower success rate.
