What is Bridge Mode on Wyze Mesh Router?
Bridge Mode allows you to turn one of your Wyze Mesh Routers into an access point for another Wyze Mesh Router.
When Bridge Mode is enabled, it prevents your networks from competing with each other by allowing all of your devices to connect to the same network. This allows for stronger communication, regardless of how many devices or Wyze Mesh Routers are in use.
To enable Bridge Mode:
  1. In the Wyze app, tap on your Wyze Mesh Router.
  2. Tap the Settings gear in the upper right-hand corner.
  3. Tap Advanced Settings.
  4. Toggle on Bridge Mode.
Note: Turning on Bridge Mode will turn off routering (NAT) function and a reboot of Wyze Mesh Router will be required.
