Does Wyze Mesh Router support port forwarding?
Yes, Wyze Mesh Router does support port forwarding.
Port forwarding allows your router to send incoming data from the Internet to a specific device on your network.
Note: You will need a DHCP Reservation already set up before you can set up port forwarding.
To turn on Port Forwarding:
  1. In the Wyze app, select your Wyze Mesh Router.
  2. Tap the gear icon in the upper right-hand corner.
  3. Tap Advanced Settings.
  4. Tap IP Address.
  5. Tap on the DHCP Reservation you would like to adjust.
  6. Tap Open A Port.
  7. Follow the on-screen steps to finish the setup, as shown here 👉 .
