How do I manually configure my Wyze Mesh Router settings?
Including how to change the Wi-Fi channel, radio power input, lock or select bandwidth, and channel width…
Wyze Mesh Router and Wyze Mesh Router Pro automatically optimize coverage, capacity, and performance in order to create seamless Wi-Fi coverage throughout your home or office.
The router automatically adjusts its radio and frequency settings based on the network conditions. This can include automatically adjusting the radio signal strength, channel width, and channel selection in order to provide the best experience. Since manual adjustments may lead to suboptimal performance, these settings cannot be manually adjusted.
Any automatic changes made to the root routers will also be automatically shared with satellite routers in order to ensure a smooth transition across your space.
