Can I use Wyze Mesh Router with my existing router?
Yes, though we recommend you replace your old router with a new Wyze Mesh Router. In some cases, your ISP may provide an all-in-one router and modem combo that cannot be replaced.
To use your new Wyze Mesh Router with your existing router:
  1. While going through the setup process for Wyze Mesh Router, connect your new router to your old router using the included Ethernet cable.
  2. During setup, make sure the Network Name (SSID) of your old router and new router are exactly the same.
  3. You're all set!
