Before you begin setup:
- Download the Wyze app on your smartphone or tablet.
- Connect your device to a 2.4 GHz Wi-Fi network.
- Unpack your Wyze Cam Pan v3 box, removing all plastic and packing materials.
- Be sure to remove the plastic film from the lens.
- Plug the camera into power using the included USB cable and power adapter.
- The camera’s status light will turn solid red when powered. When flashing, it’s ready for setup.
To set up your Wyze Cam Pan v3:
- In the Wyze app, tap Home, then tap + plus sign on the top right.
- On the Add menu, tap Device.
- Tap Cameras > Pan and Tilt Camera > Wyze Cam Pan v3.
- With your camera plugged into an outlet, tap Next in the app.
Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
- Tap the icon in the password field to display the password to ensure it was entered correctly.
Under the camera lens, single-press the SETUP button. It will say “ready to connect”.
- The camera may say “ready to connect” without pressing the SETUP button. If so, continue with setup.
- Note: Single-pressing the SETUP button does not factory reset, clear data or unbind your Wyze Cam Pan v3.
- In the app, check the box next to I heard, “Ready to connect”.
- Tap Next.
Scan the QR code on the Wyze app.
- Hold your camera up to your phone screen with the QR code displaying. It will say “QR code scanned, please wait” then “setup completed”.
- In the app, check the box next to I heard, “QR code scanned”.
- After the camera is set up and connected, it will say "setup completed".
- Tap Next. You’re set up, it’s time to name your device.
- Name your Wyze Cam Pan v3 using the text field, or by choosing a suggestion.
- Tap Finish when done.
- You may have a prompt to a free trial of Cam Plus. Tap Continue.
- Set up some automations on the Things to Try* page, or tap Skip.
- Enjoy your new Wyze device!
Additional Notes:
- Wyze Cam Pan v3 only works on 2.4 GHz Wi-Fi networks. If you are connected to a 5 GHz network, switch to a 2.4 GHz network before setting up your device.
Having trouble scanning your QR code? A few tips to help:
- Hold your camera 6-10 inches away from your phone screen.
- Slowly move the QR code on the screen away from the camera, then closer.
- Tilt your phone screen slightly in case there's a glare.
- Turn your phone upside down.
- If you're on iOS, turn off "Invert Colors".
Make sure the QR code isn't distorted.
- If you have an older device, the screen may be too small. Try a different device.
- If your screen is cracked or scratched, the code may be distorted. Try a different device.
- If you're using a beta version of the Wyze app, make sure the cursor is not on the QR code.
