Wyze Cam Pan v3 Device Details
Color: White, Black
Finish: Matte
Camera Dimensions: 124 mm (H) x 60 mm (W) x 63 mm (D)
Camera Weight: 11.29 oz (320 g)
Powering Methods
Ports: 1 micro USB
Power Cable Length: 6 feet (1.8 m)
Power Adapter Input: 110-240V (AC/DC)
Power Adapter Output: 5V/2000mA
Mounting Features
Base Screw Hole: 1/4″ – 20
CPU
1.5 GHz
Memory
128 Mb
Audio & Video
Resolution: 1920 x 1080 (1080p)
Camera
Image Sensor: 1/2.9'' CMOS
Digital zoom: 8x
Field of View: 120° lens
View Range: 360° horizontal, 180° vertical
Night Vision
4 IR LEDs (850 nm)
Video
Video encoding: H.264
Day time video: 20 FPS
Night vision: 15 FPS
Audio
Built-in speaker and microphone
2-Way Audio
Noise & Echo cancellations
Rotation Speed
Up to 110° per second
Alerts
Push notifications
Storage
Cloud Storage
Stored in the AWS Cloud
Local Storage
Supports 8 GB, 16 GB, and 32 GB microSD cards in FAT32 format
Supports up to 256 GB microSD cards in exFAT format
Data Security
End-to-end encryption
HTTPS secure transfer protocol
AES 128-bit encryption
Data Usage
1-2 MB per minute in SD, or 4-7 MB per minute in HD
Connectivity
2.4 GHz WiFi
802.11 b/g/n 2.4 GHz (Does not support 5 GHz networks)
Supports WPA and WPA2 protocols
Connectivity Requirements
Upload speed is 1.0 Mbps for SD and 1.5 Mbps for HD
Integrations
Alexa, Google Assistant, IFTTT
Phone Compatibility
Supports iOS 14.0 and Android 7.0 or later
Operating Temperature
-4°F - 122°F / -20°C - 50°C
Weather Resistance
Indoor and outdoor (IP65)
Language
English
Warranty
1-Year
