Wyze Cam OG Stacking Guide
Stack your Wyze Cam OG and Wyze Cam OG Telephoto 3x using Wyze Cam OG Stack Kit for a dual-camera system that gives you a wider field of view and 3x fixed zoom lens.
To stack your Wyze Cam OG cameras:
  1. Remove the block (with the Wyze logo) on the top of your Wyze Cam OG or Wyze Cam OG Telephoto 3x by pushing it outwards.
  2. Slide the stack mount (from the package) into the top of the camera.
    • The arrow on the sign on the stack mount should be pointing to the center of the camera. Once the stack mount is fully inserted, the mount should be centered over the camera.
  3. Screw the stack mount into the bottom of the second camera and rotate the locking pad clockwise to lock in the camera.
    • If a base stand is installed, remove this first by rotating the locking pad counterclockwise. Then, unscrew the base stand from the camera and screw the stack mount into the camera.
  4. Adjust the horizontal and vertical angles of the two cameras to the desired position. Then, rotate the locking pad on the base stand and stack mount clockwise to secure the cameras firmly into position.
  5. Plug the dual micro USB power cable into power. Connect the dual micro USB cable to both cameras, and you’re all set!
💡 Stack any combination of 2 Wyze Cam OG and Telephoto 3x cameras!
  • 1 Wyze Cam OG + 1 Telephoto 3x
  • 1 Wyze Cam OG + 1 Wyze Cam OG
  • 1 Telephoto 3x + 1 Telephoto 3x.
Additional Note:
Is one of your Wyze Cam OG devices slightly larger than your other Wyze Cam OG or Telephoto 3x? You can still stack it, just make sure the larger Wyze Cam OG is at the bottom of the stack.
Related article: Why does my new Wyze Cam OG look different than my other one?
