Wyze Cam OG Mounting Guide
Use the included mounting kit to mount your Wyze Cam OG.
Here's a video guide showing how to mount your Wyze Cam OG:
To mount your Wyze Cam OG:
  1. Remove the mounting plate by pushing it up and then pulling it away from the camera’s base.
  2. Place the mounting plate where you would like to mount your Wyze Cam OG and then mark the screw holes with a pencil.
  3. Use the included screws to screw the mounting plate into place.
  4. Attach the camera by sliding the base down into the mounting plate and pushing it down.
    • You will feel increased friction when it's locked into place.
  5. Adjust the camera to your desired position.
    • If you find that adjusting the angle of the camera is tough, loosen the dial on the bottom of the camera by turning it counterclockwise.
  6. Attach the USB cable to the included power cable.
  7. In the Wyze app, walk through setting up the device like new, or check out our Wyze Cam OG Setup Guide.
  8. You’re all set. Enjoy your new Wyze device!
Wyze Cam OG can also be mounted upside down. Once it is mounted upside down, there’s a setting within the Wyze app that allows you to rotate the live stream image.
To rotate your Wyze Cam OG's Live stream:
  1. Navigate to your Wyze Cam OG settings.
  2. Tap on Advanced Settings, then toggle Rotate Image 180° on.
Note: Although Wyze Cam OG is rated IP65 for outdoor use, the included power adapter is not. To power your camera outdoors, we recommend using Wyze Outdoor Power Adapter.
