Wyze Cam OG Tech Specs
Wyze Cam OG and Wyze Cam OG Telephoto 3x Tech Specs
Wyze Cam OG Device Details
  • Model:
    • Wyze Cam OG: WYZECGS
    • Wyze Cam OG Telephoto 3x: WYZECGT
  • Color:
    • Wyze Cam OG: White, Black
    • Wyze Cam OG Telephoto 3x: White
  • Finish: Matte
  • Dimensions:
    • Wyze Cam OG: 3.6 in x 3.0 in x 2.1 in (91.4 mm x 76.2 mm x 53.34 mm)
    • Wyze Cam OG Telephoto 3x: 1.89 in x 1.89 in x 1.89 in (48 mm x 48 mm x 48 mm)
  • Weight:
    • Wyze Cam OG: 0.48 lbs (219 g)
    • Wyze Cam OG Telephoto 3x: 0.26 lbs (116.7 g)
  • Materials:
    • Body: Plastic
    • Lens: Glass
Power
  • Cable Type: microUSB cable
  • Cable Length: 6 ft (1.8 m)
  • Power Adapter:
    • Input: 110 - 240V (AC/DC)
    • Output: 5V/1A
Video
  • Resolution: 1920 x 1080 (1080p)
  • Field of View:
    • Wyze Cam OG: 121.4° diagonal
    • Wyze Cam OG Telephoto 3x: 27° diagonal
  • Frame Rate:
    • Wyze Cam OG:
      • Daytime: 20 FPS
      • Nighttime: 15 FPS
      • Daytime: 20 FPS
      • Nighttime: 10 FPS
Night Vision
  • Color Night Vision
  • IR LEDs: 4x 850 nm
  • Spotlight LEDs: 2, 5000k, 40 lumens
    • Only applies to Wyze Cam OG
Audio
  • Microphone: Built-in, digital
  • Siren: 100-106 dB
  • 2-Way Audio, simultaneous
Alerts
  • Push notifications
Storage
  • Cloud Storage
    • Stored in the AWS Cloud
  • Local Storage
    • Supports 8 GB, 16 GB, and 32 GB microSD cards in FAT32 format
    • Supports up to 256 GB microSD cards in exFAT format
Connectivity
  • 2.4 GHz Wi-Fi
  • 802.11 b/g/n, 2.4
  • BluetoothⓇ Low Energy (BLE)
Integrations
  • Amazon Alexa, Google Assistant, and IFTTT
Supported Wyze Services
  • Cam Plus
  • Cam Protect
  • Wyze Web View
Phone Compatibility
  • Supports Android 7.0+ and iOS 14.0+ or later
Temperatures
  • Operating Temperature: -4°F - 131°F (-20°C - 55°C)
  • Storage Temperature: -40°F - 158°F (-40°C - 70°C)
Weather Resistance
  • Indoor and outdoor (IP65)
Certifications
  • FCC, IC
Language
  • English
Warranty
  • 1-Year
