You can view a live video stream of your Wyze Cam directly from the Wyze app whenever you’re connected to the internet.
To view the Live stream in the Wyze app:
- In the Wyze app, tap on the Home tab to show your device list.
- You'll have a preview of the Live stream on the Home tab.
- To view and access the settings for the Live stream, tap on the camera preview.
Live View Icon Descriptions
| Icon | Description | Wyze Cam |
| Power: Turn on/off the camera.* | All Wyze Cams | |
| Play: Start the Live stream.* | Wyze Cam Outdoor, Battery Cam Pro | |
| Retry: Tries to reconnect to the Live stream.* | All Wyze Cams | |
| Stream Quality: Toggles the video quality. | All Wyze Cams | |
| Mic OFF: The microphone is off (default). | All Wyze Cams | |
| Mic ON: The microphone is on. | All Wyze Cams | |
| Sound OFF: The audio is off (default). | All Wyze Cams | |
| Sound ON: The audio is on. | All Wyze Cams | |
| Picture-in-Picture: Toggle a smaller view out. | Wyze Cam v3 Pro, Wyze Cam v4, Wyze Battery Cam Pro, Wyze Cam Floodlight Pro, Wyze Cam OG | |
| Fullscreen: Rotates to full screen view. | All Wyze Cams | |
| Spotlight ON: The spotlight is on. | Wyze Cam v3 Pro, Wyze Cam v4, Wyze Cam Pan | |
| Spotlight OFF: The spotlight is off. | Wyze Cam v3 Pro, Wyze Cam v4, Wyze Cam Pan | |
| Floodlight OFF: The Floodlight LEDS are off. | Wyze Floodlight devices only. | |
| Floodlight ON: The Floodlight LEDS are on. | Wyze Floodlight devices only. | |
| Lamp socket OFF: The lamp socket light is off. | Wyze Cam v3/v4 | |
| Lamp socket ON: The lamp socket light is on. | Wyze Cam v3/v4 | |
| Bulb Cam OFF: The bulb cam's light is off. | Wyze Bulb Cam | |
| Bulb Cam ON: The bulb cam's light is on. | Wyze Bulb Cam |
* These icons only display on the Favorites tab.
Control Panel Icons
| SD Card: Access SD Card settings. | All Wyze Cams with local storage.** | |
| Take Photo: Takes photo, saves to Album. | All Wyze Cams | |
| Record: Records Live stream. | All Wyze Cams | |
| Smart Focus: Zoom in on motion, activity. | Wyze Cam v3 Pro, Wyze Cam v4 | |
| Siren: A loud siren plays from the camera. | All Wyze Cams | |
| Album: Opens album to view recordings, photos. | All Wyze Cams | |
| Timelapse: Opens time lapse menu. | All Wyze Cams with local storage.** | |
| Turn Off/On: Turn on/off the camera. | All Wyze Cams | |
| More: Opens control panel. | Wyze Duo Cam Doorbell. | |
| Events: Switches to events timeline. | Wyze Cam Pan devices only. | |
| Waypoints: Opens set waypoints. | Wyze Cam Pan devices only. | |
| Track Motion: Camera moves to track motion. | Wyze Cam Pan devices only. | |
| Pan Scan: Camera does a full rotation. | Wyze Cam Pan devices only. | |
| Privacy Mode: Lowers the camera, turns off audio. | Wyze Cam Pan devices only. |
**Only Wyze Cams with a microSD card slot have local storage. Which Wyze Cams have local storage?
