How do I remove my Wyze Video Doorbell Pro?
To remove your Wyze Video Doorbell Pro:
Wireless Installations
  1. Using the included screwdriver, unscrew the security screw located at the bottom of the doorbell.
  2. Slide the doorbell up and away from the wall, disengaging the locking mechanics on the back of the doorbell.
Wired Installations
  1. From your electrical panel, power off the current leading to the doorbell.
  2. Using the included screwdriver, unscrew the security screw located at the bottom of the doorbell.
  3. Slide the doorbell up and away from the wall, disengaging the locking mechanics on the back of the doorbell.
  4. Release the extension wires.
  5. Take off the wire caps and unscrew/untwist the wires from your house to the doorbell, separating the two.
