Does Wyze Video Doorbell Pro include a chime?
Yes, one Wyze Chime Pro is included with your Wyze Video Doorbell Pro. It comes already paired to your doorbell, making setup easy as pie.
Important: A Wyze Chime Pro is required to use a Wyze Video Doorbell Pro, as it provides the connection to your Wi-Fi network. Even if you use your mechanical doorbell chime, you must use the included Wyze Chime Pro as well.
