Can I use Wyze Video Doorbell Pro without the included Wyze Chime Pro?
No, the included Wyze Chime Pro is required for Wi-Fi connectivity.
Wyze Chime Pro is more than just a chime that rings when the doorbell is pressed. Your Wyze Video Doorbell Pro comes pre-paired to its own unique Wyze Chime Pro. This included Wyze Chime Pro acts like a base station, providing a stable Wi-Fi connection to your doorbell and a nice, loud chime.
What if I lose my Wyze Chime Pro? Can I get a replacement?
The included Wyze Chime Pro is paired to your specific Wyze Video Doorbell Pro from the factory. It cannot be replaced, and the doorbell cannot be paired to a new chime. If you misplace your Wyze Chime Pro, you must replace your doorbell.
Important: A Wyze Chime Pro is required to use a Wyze Video Doorbell Pro, as it provides the connection to your Wi-Fi network. Even if you use your mechanical doorbell chime, you must use the included Wyze Chime Pro as well.
