How do I factory reset Wyze Cam Floodlight Pro?
To factory reset Wyze Cam Floodlight Pro:
  1. Remove any microSD card inserted into the floodlight.
  2. With the floodlight powered on, press and hold the setup button on the back of the camera for 10 seconds until the status light on the bottom of the camera turns solid red.
  3. Once the status light starts flashing purple, set up the floodlight like new.
Note: If you’re troubleshooting issues with your Wyze Cam Floodlight Pro, be sure to Submit a Log before performing a factory reset.
