How long does it take to charge Wyze Battery Cam Pro from 0% to 100%?
It takes Wyze Battery Cam Pro about 9 hours to fully charge.
If you’re charging the battery using the provided cable, it will take about 9 hours.
If you’re using Wyze Battery Charging Dock to charge the camera’s battery, it will take about 8 hours and 30 minutes.
