How do I turn on Color Night Vision?
Turn off Night Vision (no, really).
By default, the spotlight on Wyze Battery Cam Pro will automatically turn on when it is dark and motion is detected. From the camera’s Advanced Settings, turn off Night Vision Mode. The camera will switch to color night vision.
Only a little light is needed for a clear image and a street or night light outside works. If you need more light, you can manually turn on the spotlight in the Wyze app for better illumination.
