The siren is a really loud, 80 dB speaker.
Wyze Battery Cam Pro has a speaker inside that can be used as a siren to ward off intruders.
To control the Siren feature:
- In the Wyze app, tap on your Wyze Battery Cam Pro.
Under the live stream, tap Siren. (Be careful, it’s loud!)
- To turn it off, tap Siren again.
Can another device trigger the Siren to sound?
Yes, you can do this via Automations (specifically Device & Service Triggers) in the Wyze app.
To have your Wyze Battery Cam Pro's siren sound and upload a video when your Wyze Cam Outdoor detects a person between 12:00 AM and 6:00 AM.
- In the Wyze app, tap Home, then tap the plus sign + on the top right.
- On the Add menu, tap Automation > Device & Service Trigger.
- Tap Name (Optional).
- Enter a name for the schedule. Try "Siren triggered".
- Tap Save.
- Tap Device & Service Trigger.
- Select your Wyze Cam Outdoor.
- Tap Detects a person, then Save.
- Tap Add Action
- Tap Add Action and select your Wyze Battery Cam Pro.
- Check the box next to Turn on the siren and Upload a short video to the cloud. Tap Save.
- Tap Save again, and then you’re all set!
The trigger to detect a person, rather than motion, requires a subscription to Cam Plus.
You can learn more about using Automations with Wyze Battery Cam Pro here.
