How do I use my Wyze Battery Cam Pro’s built-in spotlight?
You can adjust the built-in spotlight directly from the camera’s Live stream or settings!
To access the built-in spotlight from the live stream:
  1. In the Wyze app, tap on your Wyze Battery Cam Pro.
  2. On the camera’s live stream, tap the spotlight icon to turn it on.
    • Tap again to turn the spotlight off.
To access the built-in spotlight from the camera’s settings:
  2. Let the live stream fully load. This may take up to 7-10 seconds.
    • Note: If you have Power Saving Mode enabled for the camera, you will need to tap the Play icon in the live stream before letting it load completely.
  3. In the upper right-hand corner, tap on the Settings gear.
  4. Tap Spotlight.
  5. Adjust the brightness level by sliding the scroll bar between Min (1) and Max (100).
  6. You can also toggle on Motion to have the camera’s built-in spotlight turn on when motion is detected when it is dark.
    • Toggle Motion off to disable this feature.
Notes:
  • By default, the brightness for Wyze Battery Cam Pro’s built-in spotlight is set to 80.
  • Recording triggers a cooldown for both the camera and the spotlight. Any motion detected during this time will not be recorded or trigger the spotlight.
  • The spotlight will only turn on when dark and motion is detected then will automatically turn off after motion is no longer detected.
