Introducing Wyze Duo Cam Doorbell
Two Cameras. Two views. 2K porch protection with local microSD storage.
Heads up! 👋 You need to update your Wyze app to version 3.2 to set up your new Wyze Duo Cam Doorbell.
Wyze Duo Cam Doorbell features we're doing the two-step 🕺 for:
  • One camera for visitors, another camera for packages. With a 2K Full HD camera and a second camera pointing down, you’ll catch every visitor from head to toe and never miss a package at your door.
  • Wyze Wi-Fi Chime Included. Use the included Wyze Wi-Fi Chime for notifications and doorbell sounds. This chime is extra-special: it is compatible with ALL Wyze cameras and doorbells!
  • 24/7 Local Recording with a MicroSD Card. See what happened start to finish with continuous local recording. Get a MicroSD Card here.
  • 1-minute, Wire-Free Installation. Install it anywhere, quickly and with no wiring or tools required.
  • ...But You Can Hardwire It if You Want. Can be installed wire-free, or hardwired, which can provide an additional 6 seconds of recording length or 24/7 continuous recording (with a microSD card).
  • Dual-Band Wi-Fi Connectivity. Connect to either your 2.4 GHz or 5 GHz Wi-Fi network.
