Can I use my existing doorbell wiring to power Wyze Duo Cam Doorbell?
Yes, compatible wiring will allow Wyze Duo Cam Doorbell to charge while it’s mounted. Having constant external power will allow your doorbell to record an additional 3-6 seconds of pre-roll video before an event, allowing you to see more context for a video clip.
Note: You must have the rechargeable battery installed in Wyze Duo Cam Doorbell, even if hardwired.
Related article: Wyze Duo Cam Doorbell Installation Guide.
