Understanding your Wyze Duo Cam Doorbell Status Light
You'll find the status light on the front of your Wyze Duo Cam Doorbell. No light? Make sure the battery is charged and installed properly using the setup guide.
⚡️ All Wyze devices have a handy status light that helps determine what state the device is in.
Wyze Duo Cam Doorbell Status Light Guide
During installation:
  • Solid Red: The device is powered on and initializing.
  • Flashing Red: The device is ready for pairing.
  • Flashing Red and Blue: The device is ready to connect.
  • Flashing Blue: The device is connected and powered on, and/or motion is detected.
  • Solid Blue: The device is working properly.
After Setup:
  • Solid Red for 6s on Battery Power: Live stream is being viewed or a recording is in progress.
  • Pulsing Blue on Battery Power: Doorbell button pressed or motion detected.
  • Solid Blue while Hardwired: The device is working properly.
Wyze Wi-Fi Chime Status Light Guide
  • Solid Red: The device is powered on.
  • Flashing Red: The device is ready to connect.
  • Flashing Red and Blue: Connection is in progress.
  • Flashing Blue: The device is connected and finishing setup.
Note: Wyze Doorbell Chime Controller does not have a status light.
  • Live Support Hours:
