Can I hardwire Wyze Duo Cam Doorbell?
Yes, you can hardwire Wyze Duo Cam Doorbell!
You can hardwire your Wyze Duo Cam Doorbell for constant power and an additional ~6 seconds of pre-roll to your Event videos. Hardwiring along with a microSD card will also get you 24/7 continuous recording!
Note: Even if hardwiring, you must have the battery installed in the doorbell for setup and installation.
To hardwire your Wyze Duo Cam Doorbell:
  1. Go to our Wyze Duo Cam Doorbell Installation Guide.
  2. Follow along with the Wyze app for how to wire your doorbell.
    • You must have the included rechargeable battery installed even after wiring.
Related articles:
