Can I use my other Wyze chime with Wyze Duo Cam Doorbell?
No, you must use Wyze Wi-Fi Chime. 🔔
You have a different Wyze Chime device, like Wyze Chime Pro from Wyze Video Doorbell Pro or Wyze Chime from Wyze Video Doorbell v1. You want to know if you can use one of those with your new Wyze Duo Cam Doorbell.
Answer: No, you cannot use other Wyze chimes with Wyze Duo Cam Doorbell. Those chimes work specifically with those devices, and Wyze Chime Pro is paired to the doorbell it comes with.
But you have so many chime-y options for Wyze Duo Cam Doorbell! You can use the included Wyze Wi-Fi Chime (preferred), select a Wyze Cam to use as a chime, or wire it to your existing in-house chime (Wyze Chime Controller required).
