Yes, and you can receive notifications whenever motion is detected (using the body-heat infrared sensor). With a subscription to Cam Plus, you’ll be able to set up your notifications for when the doorbell detects people, pets, packages, and more.
- Can I use 24/7 continuous recording with Wyze Duo Cam Doorbell?
- Is Wyze Duo Cam Doorbell compatible with Alexa and Google Home?
- Can I use my other Wyze chime with Wyze Duo Cam Doorbell?
- Can I use Wyze Duo Cam Doorbell with my old back plate?
- Is motion detection available on Wyze Duo Cam Doorbell?
- Can I hardwire Wyze Duo Cam Doorbell?
- Does Wyze Duo Cam Doorbell use batteries?
- How do I manage automatic firmware updates on my Wyze Duo Cam Doorbell?
- Where can I install my Wyze doorbell?
- Do I need a technician to install Wyze Duo Cam Doorbell?
- See more
