Can I use Wyze Home Monitoring without a subscription?
Yes, you can still use your sensors without a subscription.
An active subscription is required for the Emergency Dispatch feature for Wyze Home Monitoring in the Wyze app. Without a subscription, your sensors will still work as standalone devices.
If your subscription is cancelled or expires, your Wyze Sense sensors will continue to send push notifications to the Wyze app according to your settings. When a sensors is open/closed, or motion is detected, you will still get those notifications. However, emergency services will not be dispatched.
Additional Notes:
  • An active Wyze Home Monitoring plan is required for Wyze Sense Keypad to function, and for you to enter your PIN and use your Safe Word with Noonlight.
  • Without an active subscription to Wyze Home Monitoring, you will not have 24/7 professional monitoring provided by Noonlight.
