How do I change my phone number?
Update your contact information in your Home Monitoring Settings.
Follow the steps below to update your phone number or any other contact information for your Wyze Home Monitoring system.
  1. In the Wyze app, tap Monitoring > Home Monitoring Settings > My Information > Phone Number.
  2. Add your new number, then tap Next.
    • A confirmation code will be texted to you.
  3. Check your messages and note the code.
  4. Return to the Wyze app and enter the code where prompted.
