Alarm
Use the Alarm feature on your Wyze Band to wake you up or send you an alert at a set time. Access this feature from the Wyze app by tapping Wyze Band, then Alarm.
How do I set an alarm?
  1. Tap Wyze Band > Alarm.
  2. Modify the default alarms or add a new one.
    1. To modify an alarm:
      1. Tap a preset alarms to open Edit Alarm.
      2. Modify the alarm settings.
    2. To add a new alarm:
      1. Tap Add Alarm.
  3. Tap Save.
How do I delete an alarm?
  1. In the Wyze app, go to the band product page, scroll down and tap into the Alarm section.
  2. Click “Edit” on the screen
