Works with Alexa
Wyze Band is a smartwatch that can do more than just track your steps; it lets you control your Wyze devices with your voice, or just a tap. It even works with Alexa. Wyze devices, set timers, check the weather, and more.
To authorize Alexa on your band:
  1. Tap Wyze Band > . . . > Amazon Alexa.
  2. Tap Got it, then Sign in with Amazon.
  3. Follow the on-screen instructions in the Amazon app, then tap Connect.
  4. Read the tutorial to learn more, then tap Done.
  5. You're all set!
To use Alexa with your Wyze Band, press and hold the home button and talk to your band just like you do on your Echo.
