Wyze Band Setup Guide
To set up the Wyze Band:
  2. On the Add menu, tap Device.
  3. Tap Lifestyle > Wyze Band.
  4. Connect your Wyze Band to your charger and plug it into a power source.
  5. Once it activates, wait for an alphanumeric 4-digit code to appear on your band's screen.
  6. On the Wyze app, tap on the matching 4-digit code that shows on your Wyze Band display.
  7. When "Confirm the binding" displays on your Wyze Band, tap OK.
  8. When the clock screen displays on the band, you're all set.
New to Wyze? Before starting, download the Wyze app and enable Bluetooth.
