Shortcuts
Shortcuts allow you to perform multiple actions with your Wyze devices at once. Leaving the house? You can create a shortcut to turn off the lights, plugs, and lock your Wyze Lock from a tap in the Wyze app.
And now, you can manage shortcuts with a tap on your Wyze Band.
To set up Shortcuts for your band:
  1. Open the Wyze app and tap Wyze Band.
  2. Tap on Shortcuts icon (star), then tap the Shortcuts screen.
  3. Tap the + plus sign next to the shortcuts you want to add, under Available Shortcuts.
  4. Tap Save.
To use Shortcuts on your band:
Tap on the Wyze Band screen to wake it up, then scroll and tap Shortcuts. Scroll and tap on the shortcut you want to use.
