Weather
The Weather feature on your Wyze Band displays your local weather, or the location of your choosing, for 4 days into the future.
Weather data is provided by OpenWeatherAPI.
To set up Weather on your band:
  1. Open the Wyze app and tap Wyze Band.
  2. Tap the Weather icon (Sun and cloud), then the Weather screen.
  3. Set your location automatically or manually.
    • Enable Get Location Automatically to auto update your band with your local weather.
    • Disable this setting to manually set the weather to your preferred Current City.
  4. Your settings will sync automatically to your band.
