Sleep
The Wyze Band has built-in motion sensors, so you can track your sleep patterns and duration. Check your Sleep data directly on the band's Activity folder, or from the Wyze app.
To check your Sleep data from the app:
  1. Open the Wyze app and tap Wyze Band.
  2. Tap on Activity icon, then the Activity screen.
  3. Tap Sleep.
To check your data from the band itself:
Tap on the Wyze Band screen to wake it up, then scroll and tap Activity. Swipe left to the Sleep screen to see your sleep data.
