Find My Phone
Misplaced your mobile device? As long as Bluetooth is still connected, you can use the Find My Phone feature on the Wyze Band to trigger an alarm on your device.
Note: If your phone is not connected to your band via Bluetooth, you will not be able to use this feature.
To use the Find My Phone feature:
Tap on the Wyze Band screen to wake it up. Then scroll and tap Find Phone.
