Find Band
If you've misplaced your Wyze Band, you can use the Wyze app to trigger it to vibrate for 6 seconds.
Note: If your band is out of Bluetooth range, or out of battery life, you will not be able to use this feature.
To use the Find Band feature:
  1. Open the Wyze app and tap Wyze Band.
  2. Once, connected, tap on the Find magnifying glass.
  3. Tap Find Band.
