Daily Goal
Make fitness a daily habit! The Daily Goal feature lets you set a goal for the number of steps you want to take each day. When you've reached your goal, your Wyze Band will buzz to let you know.
To set up a Daily Goal:
  1. In the Wyze app, tap Wyze Band.
  2. Scroll and tap on the Settings screen.
  3. In your Settings, tap Daily Goal.
  4. Tap the toggle next to Daily Goal to turn it on.
To change your Steps goal:
  1. On the Daily Goals screen, tap Steps.
  2. Scroll to select your goal (ex. 15,000), then tap OK to save.
