What are “modes” in Wyze Home Monitoring?
There are four modes with Wyze Home Monitoring.
Home mode is meant to monitor your home's perimeter through sensors on the doors and windows.
Away mode monitors both the outside perimeter of your home as well as the inside of it.
In Disarmed mode, there will be no on-duty sensors detecting an intrusion or triggering alarms. Doors and window sensors, even if opened, will not trigger an alarm.
Test Mode allows you to practice using Wyze Home Monitoring without worrying about alerting the monitoring center by accident. This is similar to the Disarmed mode.
